RE: Protecting balsa from heat while soldering cabanes & interplane struts
I finished all the soldering on the interplane struts without too much burned wood. I wet the balsa in the area where the heat would be applied, then installed a layer of paper between the solder joint and the wood, and wet that too. Seemed to work fine.
