RCU Forums - View Single Post - Magic 3d balancing
Old 04-29-2002 | 04:54 PM
PeteMaurek
Default Best CG for Magic
Now that everyone has had a chance to really ring these Magics out I want to know where everyone has teir CG's! I've done some re-shuffling on my battery pack and used a 40 size ARF landing gear wire as a tailskid. My CG is an acceptable approx 125MM back. Prior to this I was always flying it nose heavy.......
Where do you guys have your CG's for best hovering.......?? Doing a search I see that 140mm and 5 inches back are in the extreme range.......??
Oh! Flying mine with Irvine .53/APC 12.25x3.75/standard Futaba servos/450mah 6volt pack) Had a ST .51 in it but wanted to run this Irvine....either or both engines provided rocketing vertical.
Help!!!
