RE: a problem.....
You might want to consider a Great Planes adjustable motor mount, they work pretty good. You can adjust the width of the mount without changing the bolt patern on the fire wall. Just figure out what size engine you want to install and find the dimensions online, you can use the dimensions as a midpoint. Once you get the engine, you can adjust the mount to fit. Hope this helps.
