RE: Another smoke question
Brass melts at around 900 degrees C, stainless is around 1600 degrees C. Engine runs up to 900 degrees C have been seen, but probably not common. By the time you get that hot air off the tailcone and meeting your brass tube, you will probably be ok. But I would just use stainless, I mean, it's easy enough to get and for that application CHEAP!
