RE: Rodger Dodger Build
Thanks! I can see some similarties, and some differences also like you mentioned earlier also. I'll check with AMA for the plans, might be an interesting comparison to build both.
Here's today's update also. I only had about an hour, so limited progress this time. I drew a template for the bend in the aileron torque rods using the trailing edge of the wing, joiner plate, the ailerons to get the bend the same on both sides, and bend the wire to match. I flipped the wing upside down to bend the other side. Propped the wing up between two balsa blocks again to check vertical alignment of the torque rods, and made the necessary adjustments(one was up, other was down with the servo end centered).
