RE: Rodger Dodger Build
And some more...
I cut the servo mounting plate from 1/32" ply and glued that on the top of the wing, being careful to line it up on center. After the glue dried, the hole for the servo, which sits down into the center rib, was cut through the sheeting to match the plate. Also cut a small hole off to the side for the servo wires. I think next time, I'll offset the servo to on side as I really don't like cutting holes into the structural parts. (I didn't think about it until it was too late.) I also cut the aileron torque rods where they are inserted into the ailerons to length.
