RCU Forums - View Single Post - Formosa not taking off
Old 05-11-2005 | 12:21 AM
barelias
Default RE: Formosa not taking off
E-go brushless motor is not so famous ,here is the info came with it:
Rpm(kv) : 3700
Current : 0.70ma
Resistance : 0.064
ESC rating : 15A
wieght :66g
length: 40mm
Diameter:20mm
Shaft Diameter:2.3mm
also they recommend 11.1v li-poli
about the battery pack i made , its AAA 800mah
the motor seem to be giving good thrust,but is it ok to say if plane is not taking off then it will crash with hand launch?
The AAA's, are they as good as the sub c's?
