RE: MicroFlyer prop
Here is a procedure I learned from an "old timer". I apply CA kicker on the prop shaft with a paintbrush and let it dry. Don't spray the shaft or else you may get the activater in the motor. After a few minutes, I put a drop of CA in the propeller hole, insert a pin in the hole to insure the CA got in there and install the prop.
