hinges
Another good trick I have learned with ca hinges is to rub candle wax or crayon at the center line of the hinge before installing them. This keeps the ca glue from hardening the hinge at the bending point. I also stick a building pin through the center when installing, to keep them centered. I haven't had one split or crack in ten years since doing this.
