RE: Rodger Dodger Build
Once the epoxy had set, and I finished waking up, I added two 1/16" ply braces to the wing holder plate thingy. Also dremeled out an opening in the plate to clear the aileron torque rod ends inside the fuselage. After some sanding and gentle adjusting, got the wing seated on the fuselage and aligned. Drilled a couple of 1/8" holes for the wing bolts while keeping the wing aligned with the fuselage. Then I set the wing aside and enlarged the holes in the hold down plate to accept 4-40 blind nuts.
