RCU Forums - View Single Post - Wildhare Ultimate Build Thread - Finished & Flown
Old 05-11-2005 | 04:08 PM
Ken Bryant's Avatar
Ken Bryant
My Feedback: (10)
Default RE: Wildhare Ultimate Build Thread
2. Upper wing
a. On this surface you have to ensure that you install the center rib mount. The rest is like above.
b. Since there is no dowel to clamp to I used masking tape.
c. If you use gorilla glue make sure you pull the tape and clean under it or replace it. Otherwise you'll end up with a mess under the tape.
To clean the excess glue after it spreads out use Acetone.
ID:	270046   Click image for larger version
ID:	270047   Click image for larger version
