Dual Rates
[8D]Here is my problem....I have set up to use Flaperons..... Right Aileron servo installed into pin connection #2, Left Aileron servo installed into connection #6. The trim affects both the right and left servo.....Problem: Dual Rates work only on the right servo..when the stick is moved to the right..no effect on the left servo. When the stick is moved to the left the dual rate works on the left side, but not on the right....What have I done wrong.....
TX: 10S RX: 549 Servo: DS811 (Jitters)
