RCU Forums - View Single Post - Hypoxy - Is there a way to make it thinner and more flowable?
Old 05-12-2005 | 11:26 AM
jaka
Default RE: Hypoxy - Is there a way to make it thinner and more flowable?
Hi!
May I ask why!
Ordinary 5-30min epoxy is for gluing and is rather thick and should be, not to drop or run.
Finishing epoxy resin on the other hand should be like milk (or slightly thicker) so it could be used in fiberglassing and in mold making.
If you want to cover a fuselage or wing in 25g glassfiber ...use finishing resin (epoxy or polyester) not the glue variety. If you want to glue anything ...use 5-30min epoxy (or better yet...use Ca glue).
Regards!
Jan K
Sweden
