RE: Sig 1/4scale C/W Cub build
i am thinking about using tite bond glue for the rib stitching, i have seen one done this way and it looks good and you can make them the size you want with no trouble, then use the wet-proof tape, i called sig and ordered all the stuff they had for the koverall as i am not taking chances. They did say to use the stix it to glue it down and then use a heat gun to shrink it before putting on the first coat of nitrate dope, you can just dope it on, just either way will work, and since i already have the stix it............
