RCU Forums - View Single Post - modifying props ???
Old 05-13-2005 | 08:09 AM
pe reivers
Default RE: modifying props ???
There will be sites that tell you not to modify props, because when modified, you are on your own regarding risk insurance.
Having said that, wooden props are quite easy to modify. In any large wooden prop, there lurks that just perfect smaller prop. Unless you have an engineering education, do not make the mistake to remove material of, or near the hub, as this will seriously weaken the structure.
