RCU Forums - View Single Post - Evolution Engine Spinner Problem
Old 05-13-2005 | 10:02 AM
bruce88123
Default RE: Evolution Engine Spinner Problem
Skynyrd Man is correct. You will need to remove the flywheel to install this piece or find a spinner with a flat backplate. The drive hub is probably the easiest/best solution. You will lose just a smidge of your low idle but not enough to worry about.
Leave it to Skynyrd Man to take the last one. Nice guy. Harummmph!!
