ORIGINAL: exeter_acres
I'm assuming you do not use a throttle...it is just WOT for the tank.....correct?
I use a throttle servo. WOT on a two-ounce tank would have the plane out of sight in 45 seconds, with a couple minutes runtime remaining!
Throttling back to a slow cruise or just turning the motor off works well.
