RE: Rodger Dodger Build
Here's today's progress... It doesn't look like much, but it is actually quite a bit.
Started off by aligning and pinning the horizontal stab to the fuselage, making sure that the measurement from the tip of the stab to the wingtip is the same on both sides. Also checked to make sure that the stab sits level with the fuselage(at a right angle as the fuse has straight sides), and level as compared to the wing when viewed from the tail. Much measuring and re-adjusting here, and very time consuming to get it right. I hate this step.
