RE: Scratch Built Ignition???
actually a pair of "E" cores is needed...coils are wound on a plastic bobbin (very easy!) and then the core halfs are assembled around it and glued to each other
no doubt you've seen this kind of transformer core a million times but most likely of the laminated sheet steel type. for our high frequency use we need ferrite cores
dave
