RE: Rodger Dodger Build
I cut a slot in the elevator to add the 1/8" dowel joiner and glued that in, as well as carefulyl sanding the trailing edges of the rudder and elevator. when the elevator joiner had dried, I cut the center trailing edge away and trimmed the back side of the leading edge to fit through the rudder, and temporarily taped the elevator in place.
