RCU Forums - View Single Post - HomeLite 25cc Broken Piston Ring
Old 05-13-2005 | 07:28 PM
captinjohn
Default RE: HomeLite 25cc Broken Piston Ring
The ring may have been stuck so tight in ring grove it would have broke no matter who tried to free it up. Most times though a good soaking in acetone or spray with some kind of penetrate will do the job of freeing the ring up. A broken ring, ground square makes a good ring grove cleaner to scrape the carbon out. Bowman rings are thr best they say. Do a search and you will find more on that. If I had a extra ring I would send it to you free. I will look into finding one for you if you do not find one yourself. Good Luck Capt,n
