RCU Forums - View Single Post - Evolution Engine Spinner Problem
Old 05-14-2005 | 12:13 AM
Dukester
My Feedback: (31)
Default RE: Evolution Engine Spinner Problem
You could also cut a small circle of 1/16 ply the same size the the front of the existing prop driver (note not the same diameter as the flywheel, just the grooved section). Then drill a 1/4" hole in the center for the prop shaft and you have a quick easy spacer to offset the spinner off the flywheel. This is what I did and it works fine.
Duke
