RE: U-Can-Do 3d 46?
CeeGee,
I had the same problem with my servo travels. I picked up some new servo arms from Du Bro that are significantly longer and stronger than what was on there. By having the extra length at the servo arm you can use a smaller amount of servo travel, which should eliminate the binding.
Saito 91 goes in tonight! Can't wait for the four stroke.
-Rob
