RE: Draco CG? and weight?
Hi Alex,
As far as know the reaper ARF is bit heavier than the draco. The JJ1400 is flying the draco. But if you want "jet style" flying it is way under power. The KJ66 will be a better bet - or wait for the new JJ1800! The JJ1400 will suit the new A10X from RCARF perfectly or any other DF airframe converted to turbine.
The motor is perfect and for the price a must. Since you are not far from the factory, service would also not be a problem.
Let me know what you need and i will be happy to help.
Regards
Exclusive distributor for Skymaster RC in South Africa. Distributor for Yellow Aircraft, Trim Aircraft and JETJOE
