RCU Forums - View Single Post - G45 Ignition Problem
Old 05-15-2005 | 08:40 AM
karolh
Default RE: G45 Ignition Problem
Maybe the type of toggle switch you were using could not handle the vibrations caused by your engine. Changing to a simple Rx switch harness that is designed to handle vibrations might be a better solution in the long run. Just my 2 cents.
