RCU Forums - View Single Post - PMB setup system brilliant AND cheap
Old 05-15-2005 | 08:53 AM
Neil 777
Default RE: PMB setup system brilliant AND cheap
ORIGINAL: madmaniac
I've read the instructions, my concern though is that instead of lining up at the zero degree mark its actually 1 or so mm past it.
Hmmm thats strange mine does line up perfectly at the 0 degree mark when it is straight and i did change it so that it had 1 degree toe out which should do.
But still, the problem you are describing is weird are you saying that when the wheels are totally straight it isnt at the 0 mark but still straight?
On mine when I slide the toe-plate so that the peg on the uprite is right at the end of the cutout the marker line on the top of the upright lines up with the 1 degree toe-out line on the toe-plate rather zero degree line which you'd expect.
