RCU Forums - View Single Post - adding ailerons on Sig Senior Kadet
Old 10-07-2002 | 12:05 AM
Pappy Boyington
Default adding ailerons on Sig Senior Kadet
I built mine with strip ailerons, dropped the dihedral to 1". For extra fun I put flaps on as well, with the flaps deployed, the plane will almost hover in a slight headwind. Makes for really fun landings! I had to modify the wing to bolt it on so I would not have to keep adjusting the radio trim. I beefed up the front of the cabin with triangle stock and 1/8 inch birch ply, rigged dowel to plug in at front, bolted the rear of the wing down. It has held up really well.
