RE: U-Can-Do 3d 46?
thirsty003... On my weights, I had the stick-on weights at 1/4 ea.
I think I used under 1/2 oz... I balance mine almost like Barry, But
I do it up right, I have a screw on the firewall and this may not be
good, but it has worked for me so far.. I just put the kevlar<sp>
stunt kite string on the rudder hinge.. The string is about 4' or so
with a sliding loop at both ends, I set the plane on the garage floor,
doors closed and lift it for a second and add weight to what ever wing
needs it and lift again until both wheels set down at the same time
make my small cut it the bottom of the wing and epoxy in and re-
cover... I'm sure you have your own way.. It all works... And it does
make a difference....
Gary.... Great weather.... Thanks keep sending it over:-) My brain
timer is working a little better... No out of fuel deadsticks the last
two days:-)))) But it's kinda a off and on thing:-(
