RCU Forums - View Single Post - Need help with Thunder Tiger Lazy Cub
Old 10-02-2002 | 02:18 PM
ExperTeece
Default Need help with Thunder Tiger Lazy Cub
I am building the Thunder Tiger Lazy Cub. I am almost done but I am having trouble running the piano wire from the throttle to the servo. The instructions say that you should run the wire through the pre-drilled hole in the firewall. There is no pre-drilled hole. If I try to run it straight back from the throttle it would go through the fuel tank. Has anyone built this model that can help???
