I have just finished the Jamara Cap 230 and although it went together very well indeed the cowl leaves a lot to be desired being glassfibre it doesn`t have enough resin to fill the weave completely and is mishapen to a degree but from a distance it is ok, I have powered mine with a SuperTigre G20/23 which I had in a Sukhoi before retiring it and have fitted a smoke system as well the all up weight is around 11.5 lbs which gives a wing loading around 34 ozs/sq.in if my calculations are correct. Test flying will take place as soon as the weather settles down a bit and I will post again then with the results.
