RCU Forums - View Single Post - Thunder Tiger 120 SE: Low compression feeling
Old 05-16-2005 | 02:50 AM
Sobrinof
Default Thunder Tiger 120 SE: Low compression feeling
Hi
Two months ago, I buyed a second hand TT 120 SE.
My question is about a strange feeling when moving the propeller. It looks like if there is no compression. It is possible to move the propeller with the finger with no effort and, till now, it is not possible to start it without a starter..
When the engine is running, it goes quite well. There are only two things to comment: the idle is not very low (at least as low as I expected) and there is little difference between two positions: horizontal and nose up position (it is necessary to open the needle valve a little bit)
Do you experience the same?
Thanks in advance
