ORIGINAL: SJN
ohh man...I should have mentioned the wing bolt holes!
luckily I had forseen this problem before I began drilling........and I just wondered about how many poeple would have drilled all the way through the fusealge too........its a VERY easy mistake to make [:@]
I almost did. I did drill two holes closer together and filled them in. I forgot to put the tail wheel in prior to gluing the rudder, oops.[:'(] However, I used a spare Sullivan and think it will be better anyway. I am waiting to install the radio equipment because of the cg with the engine. I have an OS 91FS but I really wanted to use the RCV. Though, if I don't use the RCV, I could probbly easily sell it for over $300.00. Decisions, Decisions!
Have any of you heard feedback on the RCV engines, epecially the SP series? I really want a good running engine in this bird.
