RE: ReadyFly Cessna Dos and Don'ts
Surely something is wrong. Mine had the same engine and prop and took off in 50 feet or less. what does yours weigh with the floats on? Are the ailerons reflexed (raised above neutral)? Do you have enough elevator travel? (It will need more on floats than on wheels.)
Are you an experienced float flier?
Jim
