RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 05-16-2005 | 11:43 AM
  #2241
v_twin1k
Default RE: U-Can-Do 3d 46?
ORIGINAL: The MacDaddy
Ok, a little lazy to look through 89000 posts, on the UCD w/ a Futaba 9C, how do you guys get the dual ailerons and elevator servos to work? Ive read the book and still cant get it right. I am using the 7 ch FM rx btw. What needs plugged in where and how do I mix it? I also would like to put "reflex" in for harriers and ele-flaperon for tight loops. Help please....... someone at another field programmed my Somthing Extra w/ these features and I cant copy it for this airplane......it's ready to go and the radio is holding me up......I know someone knows this... I wish you could "hot sync' w/ other people's tx....some day soon im sure.
The Mac
I can try to offer a little help - I have a 7C and I know many of the features are the same.
Both of the aileron servos and elevator servos need to be plugged directly into the rx (no y-harness on the ailerons) to use the features you're after. For the ailerons, plug the master servo into channel 1, and the slave into channel 6 (the choice of ch 6 is somewhat arbitrary since you can choose which channels the flaperons operate, but I think the default is 6). Then enable the flaperon mix in your mixes menu, and both of your ailerons should be working in unison, although you may have to reverse the individual servo directions to get them operating in the correct direction. For the elevator, there is a pre-progrmmed mix that links two elevator servos together. The master elevator servo needs to be in channel 2, and the slave ch. is your choice (not sure what the default is on the 9C). With these two mixes enabled, you can then enable "Ele-Ail" or "Spoilerons" for the harrier moves.
Good luck! Hope this gets you started.
