RE: OMP Edge....Almost there!
I don't know if the CA would eat the foam in the fuse or not? I also have a pretty tight fit on the wing to fuse joint. I'm not sure when I slide the wing in place if the epoxy/polyurethane glue will get in there. Also I still have not cut out were my engine will go. Did you guys counter sink your engine onto the hardwood rails or just leave it on the outside? Thanks!
