RE: HELP!!! Alpha trainer building issue
Worst case scenario is if it makes the Futaba transmit somehow. If so, several options depending on model of Futaba.
!. Remove Futaba RF module if equipped
2. Remove crystal from Futaba
3. Obtain freq pin for Futaba transmitter and make sure not the same as yours.
Possible none of the above will be needed but make sure. This is why actual buddy box is always safest .
