RE: Het Sniper Question
Randy
Thanks for the Info I to added 1 Ounce just under the exhaust duct in about 1 from the exit of Thrust tube.
I am curious if you measured how much thrust yours is producing so I can tell if mine is in line with some of you guys.
Even though my setup pulls alot less amps according to Motocalc she should run somewhere around 90 to 110.
27amp is all mine is setup for at this point with the Mega 16 15 3.
The only other item I am not crazy about is the elevator rode to the HS85 servo I used HET fitting on the servo arm and Locktight the locking screw so the rod wouldn't loosen and using there hardware?
What about control throws and is anyone using Flaps or Speedbrake for landing?
Ian
