Thanks Barry, but do you know if i can use my jr servos or not with that? i dont think so, im scratching as it is to get this, (the old lady) i mean the angel is starting to harp
and as far as the pics CeeGee has it right but you might also note that on a reg post the "click here to upload" is not at the bottom, you have to either click on reply or quote , it states this at the bottom of the reply page that i am typing on now
, and when you click on it just click on browse next and it will bring up you prog , and pick where your pick are and double click on the pic you want and it will put it in the browse line, then click on ok, i think im confused now[&:], but if an old truck driver can figure it out so can you, i think
.there i go again.
thirsty, i think you may be right about the right thrust, but mine seems to be minimal so i just use about 3 clicks right rudder to compensate, hovers pretty stable with that.and tracks straight too.good luck with the weather there, here its spring and all we get here in the western US is wind for about 3 days and a couple days are ok and then the wind is back, over and over till summer and then well be flying in the mornings, its so hot here in the desert,( me and raideron anyways)its hotter here where i live than it is in alice springs there[8D]cant remember where Adelaide is, is it in the desert there also?wow this sure is a lot of talking, i guess ill give someone else a chance,later
