RE: GP U-Can-Do EP Does!!!
Mine is 98% finished... the ONLY item I need (and am waiting for it to arrive in the mail [:@] ) is the stick-mount for my motor. I am running a 3-cell (which hopefully won't be too heavy... if soemthing has to go, it'll be the 3-cell pack 1st for a 2) with the Hacker A20-20L outrunner with the Hacker ESC that matches. I plan on using an 11x4.7 for the maiden.
Did you stiffen the rear section of fuse between the wing and the horizontal stab?
Did you weigh your setup?
