RCU Forums - View Single Post - OS La .46
Thread: OS La .46
Old 05-17-2005 | 01:03 AM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: OS La .46
Here's a trick:
Typically-- the glow plug will be mounted in the 6 o'clock position when it's inverted. I.E.--pointing straight down.
Try remounting the engine just a little off center--so the the plug is at maybe 6:30 o'clock or 7 o'clock position.
Or go the other way and mount the engine with the plug at the 5:30 o'clock or 5 o'clock position.
Just getting the plug from being on the exact bottom will sometimes help. It keeps fuel from pooling directly on the element and cooling it down.
If a little fuel pools up in the head--but NOT directly on the plug--it can sometimes help with those low-throttle flameouts.
