What type of glue for Klett or Dubro Hinges
Just to let you know I did a test using two pieces of balsa and two dubro medium hinges. One one I used Titebond wood glue. One the second I used pacer hinge glue. I let both sit over night and then tested them. Neither would pull out with hand pressure. I got a pair of pliers and tried to pull both out. With a lot of pressure the hinge with titebond slide out with no damage to the hinge. The hinge with Pacer Hinge glue would not come out. I actually ripped the hinge apart at the metal pin. Looks like I am using Pacer hinge glue!
Chris
