RE: U-Can-Do 3d 46?
Hey Gang,
I have a quick question, I would like to know what throws you have you control surfaces set at? I have 4 flights on a just finished UCD .46, Saito .72, CG at 5 1/4, HD long servo arms maxed at about 60 degrees, hinge lines sealed, flaperons setup. Are the recommended throws for 3D really enough to make this plane perform? I know I have it set a overkill right now, when I try to transition from a waterfall to a flat spin I wind up in a knife edge fall! Hey, the plane does a nice climbing inverted flat spin! Have not got enough time on it to know if the upright flat spin will behave the same. Also experencing some coupling in KE flight any suggestions on that one? Opps I guess that is more than one question! Sorry
Sargent
