RCU Forums - View Single Post - Composite ARF Impact
Old 05-18-2005 | 07:22 PM
  #599
Pro pattern's Avatar
Pro pattern
Default RE: Impact
ORIGINAL: byoung466
Eric had discussed his rudder oscillation thought I would post some vids of my rudder oscillation the last 3 planes Ive had have done this, the previous two I built a structure to bind the cables:
Well...trying to find a better spot for them....but they will be here under Rudder Dance 1 and 2 when available:
http://www.geocities.com/b.young8070...t/hobbies.html
I havent built a lightened rudder yet, my Impact rudder was 70grams out of the box. Previous planes were a convential foam core rudder. I tightened the cables on this one and the oscillation reduced but could still be set into continuos motion. Then I moved the subtrim off center and retrim with the tab and the oscillation would not continue.
Hello everyone,
Well I’ve notice this, the past Saturday while prep. My plane for a nice Sunday flight.
Well, the plane laid in my hangar for about 4 week’s and when I went to check on everything the past
Sunday I’ve notice this. But Mine was much, much less. The movement could been @ 5mm to 15mm, but the
strange thing is, after a while it just disappeared.
Now I’m wondering what could this be?
I’m using the JR 8411 SA, on my Focus II.
Reading Brian Young post, I’m wondering if this is due that the Pull cables might be a little lose?
I’ve check them, but in my opinion they are still stiff ( tight ), but there is room for some tightening.
Using steel cable.
Just wondering out off curiosity.
Any ideas?
Regards,
Danny Koolman
www.arubarcclub.com
