RCU Forums - View Single Post - Recommendations for a .15?
Old 05-18-2005 | 08:51 PM
Andrew
Default RE: Recommendations for a .15?
ORIGINAL: combatpigg
I wonder what sort of "VOODOO" NORVEL is using to obtain more horsepower at a lower rpm than those other engines?
I went back to double check the figures just to make sure my lesdyxia hadn't kicked in and I had typed 15700 instead of 17500. I got the numbers in correctly, but perhaps the webperson flipped them -- . Well, maybe instead of a grain of salt, it should be a spoon of salt.
RPM w/ 8 x 4 3,500-15,500
RPM w/ 7 x 4 3,800-19,000
Here are the listed figures for the Big Mig -- the 8x4 doesn't even get into the max power band. I would guess that the .15's are designed to turn up, much like the .061's. If NORVEL is getting 15500 on an 8x4, I wonder what the other manufacturers are turning?
