RCU Forums - View Single Post - Hydro push rod things????
Old 10-06-2002 | 02:04 AM
Hummve
Default Hydro push rod things????
i know hydro push rod's would be efficient just make sure your tubes are connected, not kinked, and not cut and thy would be reliable. And about the wight you could get it way down with a very thin cylinder at the opposite end of the servo like the size of the hose that way would be the best to not restrictions to the flow in and out of the piston because it would be the same size as the tube.
