RE: Antenna routing
yeffy99, the base-load whips work fine. I've been using them in helicopters for 14 years, and have used them in several fixed-wing models. While some folks insist there is a range reduction with these, you couldn't prove it by me... AS LONG as common sense antenna procedures are followed.
IOW, keep it away from metal pushrods, don't install it inside a fuselage covered with metallic-backed film, etc., etc.
My LT-40 trainer has an el cheapo Hi-Tec rx with a Dean's base-load whip. I made this up for a Sig Wonder (little bitty airplane- no space inside), and transferred it to the trainer when I got tired of the Wonder and sold it. My grandson has taken this airplane almost out sight while chasing buzzards.
I use the Revolution brand whips on my helicopters, because they are a bit more durable. The Dean's do not like vibration and are prone to crack at the base in certain heli installations. But the Dean's offering is more compact and easier to mount, and works fine in airplanes.
