RE: nitro is tickin' me off
Take the air filter out and take a look in the carb to make sure there's a big enough gap for air in your idle position. You might not be allowing enough air through the intake.
If that's the case - try adjusting the throttle trim on your transmitter......or adjusting the throttle linkage. Mine will "re-adjust" itself once in a while on its own.
