RCU Forums - View Single Post - Fast, Strong servo's what are you guys using???
Old 05-20-2005 | 08:39 AM
Gotta_Fly
Default RE: Fast, Strong servo's what are you guys using???
Hey Guys
I have all these servo's you were speaking of, But what I wanted to know is this, and please by all means tell me if you think this makes since to you cause it does to me, The HS 6975 servo's has 144 ounces of torque and the speed is .10 each, Now if I use two of these per wing side that would give me 288 ounces, plus I would still be getting the incredible speed of .10,,, Now I guess what I need to know is, for a H9 cap 232 with a DA-100 , for extreme 3D will 288 ounces be enough??? also I know it's very important to have a strong servo on your rudder, so I was going to change out the servo setup in the cap and make it a pull pull, and use 3 of these 6975 chain together which will give me 432 ounces of torque and still the .10 speed,,,,,, So do you guys think this would be a good setup?? It sounds like a great idea, I also bought 12 of these servo's a few weeks ago to go in different planes but I decided to try this setup,,,, all your feedback would very much be appreciated
Randy
