Sir , I just have to say you are absolutely remarkable. I plugged the numbers into COG calculator and came up with a number in which the plane was nose heavy. Then I moved the plane on the balancer until it balanced and wouldn't you know it is perfectly balanced on the spar ? [X(] . Thanks Flyboy
