RE: Multi wing design rules?
You can go as low as .5 to .7 of the chord but at these numbers that the interference between the panels builds up a lot more drag and less lift as you get to the lower end of that range. Best is 1 to 1.3 chords spacing. As you can see from the numbers there's no set exact number. And generally thinner sections can get way with less than you can with thick sections.
